- Dec 20, 2012
- 9,408
Lines? We don't need to stinking lines!
Just joking. I think lines are a good idea when you first start grinding tools but you'll eventually get to where you don't need them. Personally, I start grinding the side cutting edge first and try to make the length of that side edge end up about 2 times the width of the bit while ALSO grinding about halfway across the width of the bit for a general purpose tool. Neither goal is all that critical but I've done so many that I can probably hit these dimensions within a few thou. Just start grinding it and don't stress over it too much.
Next, grind the end. Just grind it to produce about an 80 degree angle. You can eyeball 90 degrees with amazing accuracy so just make it a bit less than that and it will be fine. You are simply making sure you can access a shoulder, that's all.
To do the top rake angles, eyeball 1-1/2 times the width and put that estimated point at the edge of the wheel or belt, estimate your back rake angle and just grind until the pattern just reaches the tip, then stop.
Look, I know I gave you specific angles to hit. That's because the tool works well at those angles. My tools will be within a degree or less when I'm done but if you are off a degree or two, I guarantee you that the tool will still work fine. And if it doesn't or you think it might work better with a bit more relief or back rake or side rake then just go back and grind it in.
It is important to realize that all lathes are different. They have different degrees of rigidity, power, speed, wear and a different operator. Accordingly, our tools must differ if we are to maximize the performance of our specific lathe. If you think you need to be able to cut deeper, try more side rake. If your finish could be better, try more back rake (bet you thought I was going to say increase the relief angles or make the nose radius bigger, eh?). Mess with the grind and see what works for you; that is what this whole thread was about.
There are no rules when grinding lathe tools - you just gotta try it and see what happens, then figure out what you did and what worked and what didn't.
As for honing, that is a personal choice. I hone because I feel that a refined edge cuts better and lasts longer but there is certainly no rule that require you to hone your tools. I will say this, though; try honing your tools with your diamond stones, then hit it on a fine India stone and then on a Translucent or Hard Arkansas stone and see what it does to your finishes. It will make you a believer. That tool will also take a tenth off the diameter if you can dial it in.
