In an effort to add a bit more rigidity to my 12" Craftsman, I ordered the A-11 casting kit from https://mlatoolbox.com/A-11.html. Quality looks to be very nice, and at a reasonable price. This will play out as time allows, so don't expect a fast moving thread!
After getting my Lagun FTV-1 up and running, I thought I'd put it to use on the A-11 kit. Today was just a roughing in operation. Crudely trued up the casting, removing as little material as possible. Not done to any dimension yet. Plan is to remove the skin from the casting and let it sit for while. Then will rough out the T-slots with a 3/8" end mill, followed by the T-slot cutter. Then rough out the channel on the bottom, along with some initial cuts with the 1-3/8" 60 degree dovetail cutter. Then let it sit some more, before beginning to fine tune the outer dimensions, and the dovetails. Should be a fun, and hopefully useful project.
