Mitee-Grip
I just super glue some parts that can't be clamped. Take a block of metal,and clamp it up. Take a thin cut across it to assure it's parallel. Not oil at all! Super glue the parts down,make the cuts. Heat with a Mapp gas torch to release the part. Soak in acetone if needed to get glue off,but generally it just peels off while still warm enough.
My work uses double sided tape to hold sheet down on to an aluminum fixture, works great. You just need to use Nitto tape. Its so strong that you need a scraper to seperate the sheet from the fixture. Tim
I've used CA glue to hold down small parts, though not often. Never had any trouble but you do have to make sure that both surfaces are absolutely clean to get a proper bond and adequate holding strength.
