That’s also the problem. You won’t have the wheel speed for the stone to work properly. Unless your using a 10” wheel. Going slower will degrade the wheel faster than normal. It will pull the grit out instead of the grit on the wheel cutting as designed.Thats great. Atwhat rpm do you have to run it to get a nice finish, because my knee tipe mill only runs up to 2000rpm?
