- Jul 23, 2014
- 347
I have a G0704 that I have cnc-ed. Grizzly also has the short bed version, G0758 with stand for $895. I primarily work in steel and found it to be lacking in power and rigidity even as (or especially due to me being) a neophyte. Aluminum is another story, I have made .2" deep full width rough cuts with a 3/8 2 flute cheap chinese hss endmill at 20 ipm! I did very little to the machine save adding steppers for control. If you google "mill size comparison" Hoss has a page with several pics of various mills next to another mill and/or people for size reference. I found it impossible to visualize how big one mill is compared to another by the size specs on the websites. For example an X2(3990) is tiny next to the G0704/bf20.
Something to possibly consider on these small machines with a dc variable speed motor. The motor has a controller board that increases the rpm of the motor when it senses a load to try to keep the cutter at the same rpm. This works nice when you are milling a slot, for example. If you do as I and try to drill a 1" diameter hole with a silver and demming bit, the board has a difficult time working out what to do, and effectively make the drilling with anything but the lightest pressure difficult to dangerous. The large bit tends to "cog" nearly stopping at 180 degree intervals. If using a drill larger than 1/2 is a high priority, a belt drive might be worth a thought.
