I hope I'm posting in the right place, but I have a question about my mini lathe. If anyone has seen this youtube channel "Adventures with a very Small Lathe" I have the same type of lathe the only difference is mine is 14 inches, his is the 12 inch version. I'm have the same problems that he is, his lastest video is about the saddle, here is a link
. My question, can you shim a moving part? In his video you can see that the saddle is not flat, he uses some gauge blocks to lift the flat side of the saddle to get it about even, to add some more context to my question to fix this problem that me and him are having could you drill and tap some holes to affix a shim plate to the saddle( I'm a beginner I don't know if this is a very bad idea ) or would you have to remachine the V notch to make it deeper? Or would I be better off just ordering a new saddle from Little Machine Shop? Thanks, I was surprised by how quickly and helpful the people are on this forum, thanks again.
