Milwaukee Portaband Table and Stand
I found out if the table is clamped/attached directly to the sliding bumper shoe
You are probably right. It seems most people clamp the table to the bumper shoe. I just worry that it may not have been designed to handle the torque that might result from inadvertently loading the edge of the table.
I may end up clamping my table to the bumper shoe, but first i am going to see if adding a clamp to the handle will solve the problem.
In order to add a clamp I needed to drill and tap a hole in the top of the column. My freehand skills aren't to good. The column was too tall for my mill. I then realized I had a right angle attachment collecting dust in the bottom of my cabinet. I've never used it. I attached it to the mill and it worked great!
I added a cap to the post. That seems to have solved the problem.
I pulled the old video and posted a new one. Below are a link and a couple of photos.
It seems you have found the solution to that jumping problem, your table/stand looks perfectly functional .
