Here’s a pic of final installation. It is a bit longer than need be and I plan on using it for a while and once I’m happy with the shims I’ll probably shorten it a bit. Once I am sure everything is good to go, I will probably Loctite the extension onto the 5/16” rod with green Loctite assembly locking stuff I have. I forget the Loctite # .
I’ll probably shorten the stick out of the bronze bevel gear too. Not a big deal for now. I just don’t want to mess with anything until I’m happy and sure about the operation. The instructions suck. They point out 2mm of backlash. I think it’s right now but not 100% sure about it because they instruct to remove bottom cover and check backlash.
Maybe I’m missing something because I didn’t see any benefit of removing the cover to check backlash.
I do know it wasn’t working right until I played with adding and removing shims.
