Millrite mill
Might be easier to put a 3/4 - 5 LH Acme screw and nut in it as they appear to be more readily available. And you could use the same dials.
He would still need to make a custom nut in either case.
This company sells 7/8-5 nuts that look like they can be modified to fit.
The threaded mount nut can probably have a flange machined to the right dimensions added to get you back running at the least cost. The picture below is my old nut, I’m assuming your mill used the same nut.
We actually looked at that website and modifying one of those mentioned.
