Yup — you catch on fast!
Thanks! I used the original piece as the template for every cut on the saw and just set the fence based on setting the original in the next orientation for the next cut then ran the two new pieces. The sizing ended up just a little larger than the original but my buddy assured me that these are not close fit tolerances and being off by a few thou wouldn't hurt.Just got a look at the finished pieces. Nice job! When you get a a chance, practice making parts out of all sorts of plastic and plexiglass and Delrin. You will use the experience over and over again.
Thanks for the link and helpful info.I've always found this site to be quite comprehensive. I'm sure there are other resources, perhaps not quite so technical, but I still go to this one first. Machinability is rated on a 1-10 scale so once you have one or two to compare to it begins to hang together a bit more. Many plastic shops also have their own data sheets / tables for reference as well.
Research & Compare Plastics A - Z | Boedeker
www.boedeker.com
-frank
Thanks. That makes sense and having scrap definitely allows for screw ups, er, learning!Best you can do is to get a scrap of different types of plastic and experiment.
