A buddy bought a 4 post lift for his shop and needs a piece milled from UHMW as that specific piece is no longer made. This is the good one on his lift and is what we need to duplicate.
He purchased a few rectangular blocks of the UHMW figuring we might be able to machine a new one. I believe the finished piece is around 6" long and maybe almost as wide so we will be hogging off a lot of material before dialing it in and hitting the proper dimensions. There is also a 5/16 slot running the entire length, apparently, but from the picture I'm not certain how it is oriented on the piece.
My experience in machining generally is like a 0.2 out of 10. My experience with any sort of plastic is 0 out of 10. I've done a little reading on UHMW and am seeing a generally consistent set of opinions to use a new and very sharp HSS roughing endmill and to feed a fairly fast rate with a fairly heavy bite on each pass. I am also seeing that it is apparently quite slick and somewhat soft, presenting challenges for clamping it if you have only a small section to grab onto. Many opinions seem to suggest that if there is decent mass to grab with your vise, you should be okay. It also seems to be a consistent suggestion to have steady evacuation of your "chips" to keep the endmill clean so I plan to have a vac running next to the workpiece the whole time.
What is not consistent from what I'm seeing is the spindle speed I should be seeking. There are several opinions in favor of speeds from 3000 - 4000 rpm while others are suggesting that you don't want to go with a fast spindle speed but rather use a high feed rate to prevent formation of burrs and possible melting.
I guess my main questions that I know to ask are, 1) what do you guys suggest for a spindle speed and, 2) do you suggest using a coolant and, if so, what would be suitable?
If there are questions I'm not asking, I'd appreciate your input on that as well so I can go into this as well informed as possible. We do have a an extra block or two of the material to work with so I can get a sense of how to work it and not screw up the only available piece of stock, so that's a good thing.
I appreciate any input the collective wisdom may have to share with me.
Thanks!
Thanks!
