I think George has some very valid points to concider. I would worry about damaging a lathe that small. One good oops, and you could have a broken lathe too.
The drill press as a mill, well, I must admit, I did that many years ago. If your going that direction, you better find a method of keeping the M/T from falling out. Super light cuts are the only way when doing any milling on a DP. Another thing I did back then, was rig up support jacks so the table couldnt shake loose and tip.
I know I shouldnt encourage the use of a DP, but very light milling can be done with a XY table. Adding a milling attachment to a small lathe is risky at best. The use of a DP is just as bad, and you have to come to terms with you may, or may not make it through the job with out something going very worng.
