I saved all the photos in case anyone wanted me to put them into an actual blueprint and all together in a pdf.
With the authors permission that is.
No problem at all, Bill....thank you very much for doing that!
Now that I've used it for awhile, one minor change I would make to original drawing is the location of the top two clamp nuts. Instead of making them 3" c-t-c between top/bottom clamp nut locations, I would place them @ 2.72" apart c-t-c (same as the width I needed for my particular vice). Then I could easily change vice position from vertical to horizontal depending on material size/operation needed without having to move top clamp nuts every time.
Don't know why I didn't think of that little detail right from start....
