- Feb 2, 2013
- 3,960
G'day mate'
you could do that Sav,
but there will a lot be interrupted cutting and the surface finish will suffer
you could always run it through a few times taking very light cuts.
increasing the cutter speed for the last spring cut (if possible) would help out too!
then finish by wet lapping with some fine grit paper on a sheet of modern glass
there are many ways to skin a cat, i'm sure you'll invent something that works for you
