A19 LED lamps, 60 watt equivalent, about 750 lumens, are available for under $2. I accidentally popped the spherical diffuser off when I dropped my trouble light. I measured the light output from the altered light at more than 5000 lux (lumens/m^2) @ 14", more than 5x what I measured from a 60 watt incandescent bulb and 4x what was measured from an unaltered light. The bulb that I was using was a Zilotek 60 watt equivalent.
LED's have a natural illumination angle of 120º so that instead of light that is dispersed in a 360º angle , the light is concentrated in a tight cone. In the LED world, this is expressed as efficacy which is a measure of useful light. The result is that I had an intense and uniform illumination of my work surface with no interfering scattered light. It also had a shorter profile which lessened the chance of interference with my work or fixturing.
The one issue that had to be dealt with was that the raw LED's were now exposed, creating the possibility of an electrical short or damage to the LED. This can be eliminated by machining a snap-on clear lens to replace the OEM diffuser.
