Per discussion earlier in the thread, we may be going overboard chasing .001” of taper, but then, who doesn’t like a good mystery?
Hello all. I am back with this problem still.
I ran a dial indicator over my table. .002 out in 19"
Pleased with that.
Do you mean that you ran the table back and forth under an indicator mounted in the spindle or that you checked tram with a tramming attachment?
Set up the vise after cleaning.
I checked the vise across the ways., .0005 or less.
Same question as above regarding how you checked it.
How wide is the vise? That’s .0005 over what distance?
I checked a parallel to see if it was parallel. OK less than .0005
Put in a parallel in the vise and indicated the top. .001 out.
That sorta makes sense, .0005 from the vice plus .0005 from the parallel.
I moved the vise to another part of the table.
Vise was the same. .00005 or less.
Parallel. .00005 or less.
First you said the vice was .0005, now you say it's the same, but .00005. Which is it?
Same question about the parallel.
Put stock in vise on checked out parallels. .75 thick x 1.5 wide x 9 long.
3/4" new end mill, about .003 deep cut and about 3/4 cutter width.
Nasty taper.
I know “nasty” is a technical term, but can you quantify it?
The table checked at X = .000 Y =.001
What exactly does that mean?
I got taper in both directions.
The taper on the X is toward the same end of the work piece regardless of which direction you make the cut?
I have also tried a fly cutter. about .002 to .003 deep.
About the same results.
If I run an indicator across the work piece before I remove it the indicator reads .000.
That makes sense if the work piece is moving under an indicator mounted in the spindle, as the indicator would just be retracing the cutter path. That would indicate to me that there was not any cutter pull out or push into the collet.
You have my sympathy. BTDT.
Tom
