TJB heres more info on the ring roller.
The main frame is 1.5x1.5 sq tube 7" wide by 8" high. The base is 2" sq tube x 9" long.
The roller bearings are by Torrington YCRS 32 2" od. 5/8" ID.
The adjustable wheel is mild steel 3"OD knurled. I inserted 2 bearings 6202-RS-16 front and back. All the bolts are 5/8" NC grd.5.
The adjusting screw is 5/8"-8 acme RH threaded x 12" long, from an old vise. The top plate is 1/4" F bar. I made a acme threaded insert and welded to the fixed top/back plate, which is then bolted to the sq. tube up rights.
. The front and back guides are also 1/4"F bar. The sliding insert that holds the adjusting wheel is also 1.5x1.5 sq. tube.. The turning handle is 13" long 5/16" F bar. I put a 5/8" spacer be hind the adjusting roller for clearance.
All the material was from my scrap pile. And since I had a can of nice blue paint from an other project why not paint it blue, hides the rust.
Any other questions let me know.
View attachment 298745View attachment 298745View attachment 298746View attachment 298746View attachment 298747View attachment 298747View attachment 298748View attachment 298748View attachment 298749View attachment 298749View attachment 298750View attachment 298750
