- Nov 22, 2019
- 14
A few suggestions:
1. Are you seeing it on all axis or just the X axis? If just on one axis did you check the scale resolution settings and/or change any of the error compensation parameters? Sometimes there is a reset procedure for the DRO.
2. The error seems to be a cumulative error, is it a linear cumulative error or is it random.
3. Error compensation is usually over a fixed distance in increments over the length of the scale, not based on the total length. A 5 micron scale should track within 1 digit, so something like +/- 0.0002" over something like 0.5 to 1"
4. If the error is not linear/cumulative at the same amount it is possible that it is either a read error due to alignment or possibly contamination. Is this occurring on a new install/machine or is this something new with an older machine.
5. I had a similar issue on a mill, and the error was a lead screw error because the pitch was 3 mm, so I got a fixed cumulative error and required a DRO to get an accurate measurement readings. The error was very similar to what you are experiencing.
I would take a look at this thread, you need to quantify what is in error and in more detail:
Ideas for proving DRO calibration
I am installing a nifty Chinese DRO and set of glass scales on my grizzly 12x36. I am done , except the z axis chip shield. I am pausing here to check the accuracy of the set up, as I am running out of time to complain if there is a problem. I don't need a chip shield to test these, so it can...www.hobby-machinist.com
1) I see it in X and Y of about the same amount.
2) It sure seems repeatable and consistent at around .016" per 1.000" - X and Y.
4) This is a pretty new mill and might have been there since I set it up in December.
