Clocks used for scientific purposes were calibrated against the motion of stars, an independent and highly accurate standard. I presume that this was done here too. Of course it wouldn't be perfect, but time is relative, after all. ;-)
Kater's pendulum and the clock (basically the clock's pendulum) were closely, but not perfectly, synchronized. When off slightly, you can compute a period measurement of very high accuracy by measuring the beat frequency: the frequency at which the two pendulums (the clock's and the special one) coincide (the "method of coincidences"). This is similar to how a vernier caliper works.
My objective (in principle) is to do as good a job as Kater did.
As for validation, I'd first hope to find a value that is within expectations compared to the average value of g on earth, which is 9.80665 m/s^2 (32.1740 ft/s^2), say +/- 0.3% just to check that I'm in-range.
After that, I could probably find data (i.e. maps) that gives a better value for my particular location. Beyond that, I'd have to find a particular spot or lab at which a high resolution measurement was made, and set up there.
But it's also, and mostly, just to have fun with an interesting challenge!
Thank you for the offer. Just thinking out-loud:
A shorter pendulum is certainly possible, and it would open up more avenues for a length measurement. A meter-long pendulum swings with a period of about a second. A half-second period would be 43.5 cm or about 17 inches.
There would be a penalty somewhere, but my guess is not very much in the resolution of the period measurement given more modern techniques of measuring time.
I expect I'd measure the period with an oscilloscope (which I have) and a light sensor of some sort, which would be cut by a thin blade carried at both ends of the pendulum. I think this could get me down to under 100 ns resolution without too much trouble, and possibly under 10 or even 1 if done right. With this and some averaging, I think I could hope for 7+ digits of time resolution. If that worked out, I think the period measurement component is not the hardest part, and using a smaller pendulum (within reason) would not necessarily become the major limitation (I think L will remain that). Later pendulums were indeed smaller than Kater's, too.
But I kind of like the idea of sticking with the historical meter-long pendulum.
