I've got a nice vintage precision spirit level. It is not as sensitive as a professional machinist level, but 3-4 times more sensitive than common spirit levels for e.g. wood work.
The motor and stand are test mounted on the lathe without remarks and a flat belt is ordered. I TIG-welded the stand and it looked like sh-t since I'm not used to TIG welding. So I reinforced the critical welds with the MIG afterwards. It was silly to even try the TIG on this type of work but I though it would be a rewarding exercise.
The color is exactly the same as on the lathe. The lathe looks a lot more green on the photo though due to light effect. There is only one more layer of paint to do and then I can start the assembly.
A small setback in the process showed up today. The paint seemed to be in a good condition. But on all horizontal surfaces where the lathe have been hit with tools and whatever, the paint is very easy to remove. I guess that cutting fluids and other stuff have undermined the paint during all these years. So it is just to remove everything that is not solid and repaint these parts. I hope this also means the final result will be a bit better than planned. The first pic is a place where the paint it great and is quite solid. The next pic are areas where all paint needs to be removed.
