- Nov 14, 2014
- 851
Way cool. This should be a 'sticky'!
..........snip...........
What’s a Silver and Deming Drill?
Again, I have no idea how that name came about but the long and short of it is that they are drill bit sizes from .5” dia to 1.5” dia. Most have ½” shanks. They are not made of silver. Large bits can take huge bites of materials and may not be suitable for a hand drill. A drill press or mill is recommended for these larger sizes.
......snip......
Jim
Surface roughness, in its various forms of specification is measure with a profilometer. I have one. There are several ways to evaluate surface finish, and these instruments can give various readouts according to what parameters you wish to see.
Most machinists however, use a fingernail comparator to make a physical comparison to a sample, usually machined in small sections on a plate. Each method, such as turning, milling, grinding, etc, have their own characteristics, and these sample plates have several of each, typically what is seen on engineering drawings. 500µ, 250µ, 125µ, 63µ, 32µ, 16µ etc.
Excellent reading for the home shop machinist…good job. But, if you think you have finally stopped the world from misusing/transposing the words “precision” and “accuracy”, think again. I tried for 40 years with no luck!
