- Oct 11, 2019
- 139
A friend of mine mentioned something and a light bulb went off in the back of my head.....
could I........ try normal single point threading except keep the half nut locked onto the feed rod.....
stop the lathe, flip the forward reverse lever and back out the cutting tool turn the lathe on and back up the cutter, turn the lathe off, flip the forward reverse lever again and set the cutter properly then turn the lathe back on.....
My friend said that doesn't work for him as it looses Sync ...... Personally I don't see how it can, as both idler gears are the same,.... but when moving that lever they don't always mesh up good... and that might be why.....
has anyone ever tried that method ? does it work ? or avoid it with prejustice !
I think reversing the motor sounds alot more Sure ...... still need that 3 pole switch though !
later !
Bob......
later !
Bob......
