- Jan 5, 2014
- 1,004
Hello again. I am mounting a stepper motor onto a thickness sander and removing the crank. I don't want to take it apart but want to do the machining more or less by hand. I'll have a simple control panel of some sort.
I plan on a bolt-circle template for the four small screws for the stepper and that mounts to the 1/2" center shaft, but I want to counterbore ~1/2" diameter shallow, coplanar flats for standoffs to sit flat at each mounting hole. The material is cast iron and there isn't that much thickness to play with. Ideas for doing this by hand? The counter-bore bits I have are not large enough diameter for the flats.
I was thinking about another (thick) template with 1/2"+ holes and a stubby end-mill and a hand-drill. I wonder if that will work? I've got one chance.
