Metal lathe enterprise 1550 doesn't start
Kroyjutras
Dec 7, 2020
6
Hi there. I would like to have some help.
Maybe 15 years ago I took apart transmission of my lathe to change bearing and forgot about it until recently.
Now... Bearings changed and transmission rebuild.
But it doesn't start.
Got power in.
Relay click in and stop with lever and brake.
I do have the manual but lack knowledge to understand electrical diagram.
Anybody can help ?
I have a relay on my lathe that sticks once in a great while and have to
manually push it in then it works fine for months or more.....................................YMMV
Thanks for the reply. I greatly appreciate it.
I try it and without success.
If there are any reset buttons in the panel, try resetting them.
Also check those four fuses to determine if they are faulty (blown)
Thank you for the reply.
There was one blown.
I changed it.
It blew again.
I connect wire in front panel that was hanging.
I changed it again and restarted.
It hold but motor doesn't start
Here is the electrical diagram
  • Enterprise 1550 Manual_210126_160936.PDF
It's fixed !!!!!!
Thanks guys for the support!!!
There was a bad connection!!
Can you determine if the forward (fc) or reverse (rc) contactors are pulling?
-Mark
Never mind you got it, glad it's fixed
