Plumbing in olden days was done using cast iron pipes. The connections were made using lead and oakum so it was
common for plumbers to have a gasoline powered heater with a large pot made of cast iron and filled with lead. It's
obvious now that the plumbers were contaminating themselves by working with the stuff but the biological effects are
commonly not seen for years. Lead concentrates in the bones and the body has no way to remove it so not something
to be used casually. Overheating lead generates lead fumes that is more toxic than people realize. It's best to melt
the lead outside with just enough heat to get the job done. I found this photo on the internet.
I have one of these old heaters. It holds 2.5 gallons of gasoline and is capable of generating a lot of heat. I use it solely
for stuff like heating up the diesel tractor on a cold day. The tank has a pressure gauge on it and uses a small hand operated
air piston to pump it up. I generally pump it to twenty PSI which is plenty and the gauge goes well over that to eighty PSI
or so. It makes one think when pumping air pressure into a canister of gasoline! The amazing part is that it is probably
a hundred years old and still works well, more than I can say for most stuff made these days.
It would be a good idea to read up on the toxicities of lead before heating up a pot of it. If you do, you will be a lot
more careful with the handling of it. That's not to say that I might make another lead hammer or two but will be mindful in
doing so.
