Alright so as I suspected, I ended up making a new lid, which also gave me an opportunity to document the process I used for the bucket as well.
Several strips are cut, cleaned and welded together to make one long band, at least slightly longer than the circumference of the lid.
A thick aluminium bar with a convenient ledge on it is underneath, helps align the pieces.
Weights on the sheet just keeps it down to free up my hands.
Absolut chaos in the background, sorry about that, quite behind on cleaning up.
Either way the strip gets sent around a couple of times in my real ****ty roller.
The radius is quite forgiving, as long as you get it vaguely close to what you want to end up with, you're good to go.
Also the welds need to be blended decently to roll nicely.
A brim was cut from the cutout from making the buckets bottom brim, roughly tacked on.
Unfortunately I was tired and started making mistakes here by taking shortcuts.
I had already tacked it halfway around when I noticed the brims outer diameter was larger than the rolled ring, definitely not close enough for me to "hide" it.
Stupid call of the moment was to cut the ring and keep tacking, makes problems further down the road.
Here's todays little experiment.
I tried rolling this in an english wheel to get some shape to it.
Overall finish is pretty garbage, but for my second try ever I'm pretty satisfied.
This is however when the ring/brim mismatch showed up.
The lid was matched to the ring and is now too small because I increased the size of the ring to fit the brim...
Instead of taking a step back I just kept tacking, trying to force things into place.
Considering how thin the steel is on the top it's amazingly strong now when it has some shape to it, easily pulled everything else out of shape.
Live and learn I guess.
So now I have a furnace that looks like some droid from star-wars.
I put the foil back on after taking the photo ofc.
Also it was horrible trying to lift the now HEAVY furnace off the workbench, but once down I'm real happy with the wheels on it.
The entire lid will be filled with perlite-cement, maybe also some kind of reinforcement to help it stay in place besides the brim piece.
I made the diameter as such that the steel brim is several centimeters away from the firebricks(super warm), so it should be perlite-cement on perlite-cement(less warm).
