Use a converter or digital calipers calipers to convert from one system to the other.
I use mainly metric and only use imperial when I have to.
I got so fed up with the 1.25 mm (approx) travel per turn on my cross slide dial that I made an M10x1 screw and nut along with a 100 divisions dial so its all metric now and easy to work out .
I say stick with what you are used to as theres less chance of making mistakes.
I'm also into astronomy and telescope making.
80mm long focal length refractor
I came into possession of a matched pair of Jaeger 83mm dia lens of f15 focal length. Although a focal length this long is somewhat against current practice I thought it might make a good project. As this project is a long one I thought rather than just put the odd bit in the “what did you do in...www.hobby-machinist.comThe Giant Binocular
Its time to re-visit the binocular. This is roughly what I want. I started these over 5 years ago but got side tracked building recumbent bicycles. Now I've almost finished the refractor I've started back on these. This is being built entirely from scratch including grinding and polishing the...www.hobby-machinist.com
very nice!, i went through and read both the threads!
