Alphawolf45
Retired from the military - 20 years with no war skill - still makes me laugh.
The most complicated job I have tackled is a set of double set triggers for a Sharps Borchardt action. Got the action after it had been through a fire so everything was nice and soft. Got the dimensions for the DSTs from the Single Shot Rifle Association, they had two sets, one by Jim Lofland and one by Frank Zitka. Both are essentially the same with differences and both are very easy to do - just takes a lot of time. It was my fifth project on my vertical mill and one of the most satisfying when it was done and actually worked.
What kind of steel did you use for the Maynard receiver and the barrel stub ?
How did you measure for the pin hole and touch hole in the receiver ?
Not being the sharpest knife in the drawer, I would have taken a rod - put a point on it, slide it in the barrel and made sure it centered on the touch hole in the cartridge. Then put the barrel in the receiver and lightly tapped it to get the location. Math is not my friend so I could never have measured it and gotten it anywhere near the correct location.
MaynardG
MaynardG
