MATH Formula for figuring 1000ths into degree's
If you had an angle block set you could set your compound angle off of the chuck face using the proper angle needed.
Patrick
I forgot to add
On the setup I forgot to say I will also use the
tail stock dead center.......so the protractor is now between centers reading "0" on the
left and 180* on the tailstock, if not, move the crosslide in or out till it reads 0 and 180*,
then swivel the compound to check for concentricy just like dialing in a 4 jaw. No doubt
a test indicator can also be used dialing in the protractor. I guess after a perfect setup
you could glue or screw the protractor to the block if need be I choose not; fits in draw
better.
GK1918
I like your approach on this, I have a Grizzly lathe that has the degree marks in the cross-slide on the operator side of the compound. The problem is at about 25 degrees, due to the width of the cross-side, I run out of marks, or the compound covers them. I currently fumble with a protractor.
Did that 1937 Hudson Terraplane have an electric shift on the steering column? A friend of mine had a 1935 Terraplne coupe during our teen years, -- many memories brought back, we skipped choir practice a lot. I think the Hudson cars were ahead of their time.
Have a good day
Ray
I find it so intriguing how many ways machinist comes up with ways to do things its truly fascinating but then again their machists, and i love hereing about the different ways to achieve the same outcome, awesome :))mac
