Don't know why I didn't see it before,but the back surface of that chuck looks messed with. WHAT are all those file marks about? That surface should be pristine grinding marks,not all file marks.
Ray,what do you mean the other parts are meaningless? They all contribute to how true the collet holding surfaces run. I think someone has messed the back up. I am more and more drawn to SEND IT BACK!!!!!!
O.K.,with that in mind, IF IT WERE DO OR DIE,I'd chuck a VERY TRUE piece of precision ground shafting(NOT DRILL ROD!!!) in a collet-the LARGEST size possible that will go clear through the collet. Clamp the protruding rod in the FRONT end into a 4 jaw chuck. The collet chuck would be facing the 4 jaw. First having removed the D4 pins. I also would have FIRST taken a light grind with a GOOD tool post grinder across the face of the 4 jaw jaws in insure parallelism. Otherwise something held close to the chuck could indicate true,but away from the chuck it could waggle.
Having prepared the 4 jaw to maximum parallelism,chuck your precision ground rod. There must be enough room allowed to get an indicator between them. You MUST get the rod indicated to .0001" if you want your collet chuck to be that accurate. And,don't forget to use a collet that is KNOWN TO BE TRUE. Have any Hardinges?
Take a very light grind across the rear end of the chuck until it JUST cleans up. Remember,you first had to make sure the mating surfaces of the spindle and chuck did work,and you don't want to change that. You might get away with taking A FEW THOU off the back of the chuck. I am concerned that the chuck might then not mate up. As stubborn as I am,I'd carefully remove the whole assembly,turn it around,and with thin blue,check it against the spindle and re grind he taper as necessary after truing the back surface with those file marks.
I dunno,I think it really would be best to send it back.
Any argument to my last procedure here? With the low forces of grinding,I doubt rigidity would be a problem. But,I stress,use a GOOD tool post grinder. And an ACCURATE piece of precision ground shafting. Drill rod looks nice,but it has lobes on it and it just isn't good enough. My favorite grinder is my new Themac.
