- Aug 6, 2013
- 336
I know this thread is a little old, but thought I'd chime in anyway.
I have a VistaCNC pendant and use it for manual cutting on my CNC mill quite often for simple things especially like squaring or surfacing a part or edge.
I simply set the slow jog speed in mach 3 to match my desired cut speed and use continuous mode. It will move at the slow jog speed as long as the wheel is rotated. The speed the pendant wheel is rotated doesn't matter and the cut speed doesn't vary and is consistent as long as the wheel is turning no matter how fast or slow. As soon as I stop turning the wheel, movement stops. Rotate clockwise for axis positive movement and counterclockwise for negative movement. Select which axis to move by the press/selection of a button. I can fine tune position by selecting step mode. Set any step amount (hundreth, thou, 10 thou etc) in Mach3 and select step mode and it will move one step each wheel detent very precisely. Most models have a LCD that shows the "DRO" position of the selected axis without having to even look at the computer screen. All in all really handy... like a DRO and powerfeed on steriods. I'm not affiliated with Vistacnc in any way but I highly recommend their pendants. Once you use one a bit it becomes pretty much second nature to quickly do "manual" milling on a CNC mill.
