I have seen the Parker o ring book, but don’t understand it. I am in calculus 2 right now, but I still find it hard to understand the machinist handbook o ring tables. I am making a pressure to force gauge, so I believe it is a static seal. I have tested it with a buna n O ring and I got 8,000 psi with a 1/2 inch with a 1/2 inch press ram. The bore is 1 square inch, so I get 1 psi per lb of force on the gauge. I used a parting blade to make the groove. The whole unit is made out of aluminum. This was for prototyping, but I’m not sure it will hold up for very long. The tolerances are not great and the finish is poor compared to what a professionally manufactured hydraulic cylinder would be. If I was far enough in my engineering degree I probably wouldn’t need to ask if aluminum is ok to be making this unit out of, but it was the cheapest option for prototyping. I wish my skills were high enough to do the math to see if the metal could handle the pressures and all the other calculations needed to make the right part the first time out of the right materials.
Does anyone have a diagram of the degrees the tool should be? I will look in the machinist handbook tomorrow for the rest in between work and class.
