Making Dividing Plates
T. J.
H-M Supporter - Gold Member
Oct 31, 2015
481
I need to make a couple of new plates for my dividing head and I’m wondering what’s the best way to make the holes - about 500 of them :eek:. Has anybody done this?
Is drilling only accurate enough, or do they need to be reamed? If reaming is best, I was considering getting a combo drill/reamer to cut down on tool changes. They’re kinda pricey, but if one would do the job I think it might be worth it.
No personal experience, but per N. Kettle in Model Engineer v142 #3540 (2 July 1976), he used a 1/8" x 5/16" center drill to drill 1,500+ holes in the 4, Ø6" plates for the dividing head he made for a R.T.2 Rotary Table (I'd send/upload a copy of the article, but I'm a great respecter of Copyrights). You may be able to download a copy (or ask for a copy since it was 48 years ago) from ME. N. Kettle also noted that he based his design in part on a Myford Dividing Head; at his request, Myford provided a full set of drawings for his use!
Two things come to my mind:
1) If the number of holes in a single circle and diameter of those holes is large, you run the risk of drilling a ring right off the disc. If required you can use two circles and alternate in/out to make them fit without "trepanning" the plate.
2) Although drilling is never a precise operation, the offset introduced by any drilling errors should be reduced by the gear ratio of the worm and wheel inside the dividing head.
I hope you post some follow-up of your efforts.
Brian
From my perspective, a center drill would be superior to a drill-reamer combo. I have made several
dividing plates with a center drill and had good results making gears. Center drills are highly accurate
but not so with a standard drill bit. It seems to me that a drill-reamer combo would make accurate holes
in inaccurate places.
You might want to check eBay to see if there are any plates that will fit your dividing head. Last year I bought a new set of #4, #5, #6, and #7 plates for my L-W Chuck Co. dividing head for less than it would have cost to buy the combination drill/reamer alone. The same seller currently has complete sets available for Ellis and Carroll dividing heads. My L-W Chuck Co. uses the same ones as the Ellis dividing heads.
Non standard plates or to make missing plates? I have some different assorted dividing head plates, might be one that fits your head in there
I have the 3 standard plates up to 49 holes. My immediate need is to make 3 gears of 57, 63, and 69 teeth, which necessitates a new plate. I figured I would add some other hole circles as well to fill the gaps.
That’s a great find projectnut! My dividing head is an L-W Chuck model as well, and it looks like he has what I need.
I’m going to contact the seller about getting those individual plates. Thanks!
