4
4GSR
Forum Guest
Register Today
I started a thread on my B & S 612 Surface Grinder covering making a new cross feed screw.
Here's a few hints / tricks on machining new screws that I've used over the years.
1) Buy a stocked length of your favorite screw material if you can. That way you can skip most of this mentioned below.
2) Use a on size material for your screw, rather it's cold rolled steel, turned, ground, & polished stress proof, drill rod. It just makes life much easier doing so. Avoid using hot rolled materials, even if its all you have. For my new screw, I used a piece of 7/8" OD 1018 CRS I bought from a local source. I wanted drill rod, 3/4" was the biggest they had without ordering a piece.
3) Use a lathe equipped with a follow rest. You pretty much must have one to get it done correctly. I used my old faithful 9" SBL to cut the new screw.
4) use a threading tool ground for a pitch or two smaller than what you are cutting. Example, the thread I cut for the cross feed screw I made was a 10-pitch Acme thread. I used a 14-pitch tool I had on hand, 12-pitch would have worked too, if I had one.
More to come....
More to come....
