- Oct 31, 2015
- 476
I need to make a tapered gib for the cross slide of an Enco lathe and I could use some advice from someone who’s done this. I’ve got the basic process and work holding problems figured out (I think). My question has to do with how much extra material to allow for fitting the gib. The length of the finished gib will be 12.25”. It is .355” on the thick end and 0.213” on the thin end (0.0116” taper per inch). The dovetail angle is 60 degrees.
I’ve studied the chapter in the Connelly book where he discussed gib construction. In the example he gives, he suggests making the gib 3” longer than it’s finished length. I understand this - when scraping the gib, you’re going to be removing material and it will insert farther into the cross slide. When you’re done, you cut off the excess on each end.
This is what I don’t get. He goes on to suggest that you should add 1 - 2 times the taper per inch (0.020” in his example, 0.023” for mine) of thickness to the machined gib to allow for fitting. That’s a ton of material to remove by scraping! Why this extra safety margin? I’m inclined to make this margin much smaller (say 0.001-0.002”), but I want to make sure I’m now missing something. What do y’all think?
