Making a square head nail out of a 1/4” by 2” long stainless steel 304 hex head lag bolt
If you have a forge, this would be an easy project. First hot rasp the threads off. Too dangerous to just hammer down and risk a cold shut. Then draw a square taper to a point and round, if desired. Forge head square, using a bolster over the pritchel if the requirements specify it.
Hi everyone,
I am a beginner, and need any advice on how I can turn down the OD of the lag bolt to about 3/32”.
My two lathes only have chucks, which are in the way of my cutter.
I already heated the heads and hammered them square.
Any help will be much appreciated!
Thanks in advance,
J
Another thought (which I realize is sacrilege to antique collectors) would be to drill the door hardware out to 1/4".
Have you checked out a place like this? Not stainless but they do have galvanized square cut nails.
Yes, they do not sell square head round nails.
Thanks
J
I I only have a propane torch which I used to square the hex head on the anvil jaw of my post leg vice.
could I use a propane torch to forge the shank little by little ?
Why is a cold shut dangerous, please excuse my ignorance.
thanks
J
