- Dec 18, 2019
- 7,428
The chuck key that comes with my mini-lathe is just long enough to do the job, but not long enough to be convenient. By not long enough, I often bust my knuckles, or manage to hit the dial indicator because the handles are not far enough away from the chuck. So I'd like to change that. Handles could be a little longer, but, that's not as important as increasing the body length. I have 2 chucks, a 3J and a 4J. The keys are annoyingly too short.
I have some O1 steel in 0.625" diameter for the key and 0.3425" diameter for the handle. I would turn down the end of the body for the key so that the diameter is about sqrt(2)*key width. Not sure how to make the key square. So far, the only idea I have come up with is a collet in a square collet block to grab the stock. That way, one could then just put the collet block in a vise and file the section. Then rotate the block 90 degrees and file again, etc. Is there a better approach? Don't own any collets, nor a collet block, so I'd like to know if there is a better way, so I can minimize my cost, and maximize the likelihood of two properly fitting chuck keys.
Should I attempt to harden the square key afterwards? They are not that big, only about 0.25" across the flats, for one of them and about 0.3" for the other.
