On a large-ish lathe with a 4 jaw chuck plus a boring bar you could make the offset hole with ease
The photo below is of a Harbor Freight 2" head and 1/2" shank boring bars. Mine were from Enco years ago, can't speak to the quality (or lack thereof) of the HF product.
Boring in the mill!! The best way to do it is to center the starting hole. You can drill it until it is big enough to start boring and keep on boring. When you get close to a finished size start checking for a fit.I made this:
out of some scrap dock a day or two ago (that explains the two extra holes -- one near the bottom, one at the edge of the main hole). The large hole is 1.125 (+/- .05 !), and I made it by chucking up a cheap hole-saw into a chuck in the milling machine and gradually working my way through the 1/4" aluminum plate. It was blind luck that I had a hole-saw of the size I needed, and after I sharpened up the teeth a bit, it all went OK. But before I found that hole-saw, I was saying to myself, "How the heck am I gonna cut this hole? I don't have any 1 1/8 drills..."
In wood, I'd probably use a trammel cutter, which tends to cut a rough hole, and then smoothed things up a bit with rasps/sandpaper/whatever. If the lathes at the shop had 4-jaw chucks, I could have squared off the piece (the bottom inch isn't needed, but it didn't need to be cut off either) and cut the hole on a lathe. But supposing that the thing above -- rectangular, with the hole off-center --- really was what I needed, is there something like a trammel-cutter (but perhaps a little more sophisticated and less subject to vibration, etc.) that I could have used in the milling machine?
Those are great for general drilling also. I am still on the same on that has drilled well over 100 holes in truck frames. I think one thing going for them, is the cutting surface changes as you progress through the hole, so they do not get as hot as a conventional drill. Also work great in sheet metal. Just wish I could find one that would make the 2" holes in thin metal, needed for gauges.
Recommend to every one, if you have not tried one, give them a chance before blowing them off as a gimmick.
