Making a large-ish hole in aluminum plate
spike7638
Feb 8, 2016
77
I made this:
out of some scrap dock a day or two ago (that explains the two extra holes -- one near the bottom, one at the edge of the main hole). The large hole is 1.125 (+/- .05 !), and I made it by chucking up a cheap hole-saw into a chuck in the milling machine and gradually working my way through the 1/4" aluminum plate. It was blind luck that I had a hole-saw of the size I needed, and after I sharpened up the teeth a bit, it all went OK. But before I found that hole-saw, I was saying to myself, "How the heck am I gonna cut this hole? I don't have any 1 1/8 drills..."
In wood, I'd probably use a trammel cutter, which tends to cut a rough hole, and then smoothed things up a bit with rasps/sandpaper/whatever. If the lathes at the shop had 4-jaw chucks, I could have squared off the piece (the bottom inch isn't needed, but it didn't need to be cut off either) and cut the hole on a lathe. But supposing that the thing above -- rectangular, with the hole off-center --- really was what I needed, is there something like a trammel-cutter (but perhaps a little more sophisticated and less subject to vibration, etc.) that I could have used in the milling machine?
The tool you seek is a boring head. Criterion makes a deluxe model.
Thanks.
Can you amplify a little bit? (I'm really an almost complete novice). This video
shows how I could enlarge a hole...so do I start with a 1/2-inch drill, say, and then successively enlarge with the boring head
until I reach 1.25"?
It's called a trepanning tool. This one is shop made (and won't make a hole that small), but they are available.
Your money is probably better spent on a set of these,
and a boring head.
If you have a set of hole saws ( not all that expensive ), use a 1-1 1/8" hole saw, then boring bar to size. Mike
Yes , there is . :grin:
Edit . Thanks Mr Whoopie .
A S&D drill would do the job also as well as a carbide insert drill . Not knowing what you own , you done good .
The full answer depends on a number of conditions:
1) what equipment you already have (and it's size),
2) how much you want to invest in new equipment to get it done, and
3) the required precision of the result.
...and there's lots of ways to do it.
start a hole with:
-drill-bit, (hand drill, drill-press, lathe or mill)
-hole saw or annular cutter (drill press , lathe or mill)
-trepanning (lathe or mill)
increase hole size and take to precise size with:
-boring bar and or boring head (lathe or mill)
other options:
-water-jet
-plasma cutter
-brino
