- Oct 4, 2016
- 7,151
OK making progress, with a learning curve,this is the jig I made to make the gaff. For the handle, while knurling, the tubing was getting pushed into the chuck, and I lost real estate on the handle, and it was short. I'm also learning the amount of length needed for the hook radius, this one is a bit long for shaft length, so that will be adjusted. Then the handle can be welded on. The air over pneumatic 20 ton press works awesome, but at ten tons you can hear it labor, so that's probably the max
