I did a little more work done on the screw I made a few passes on the thread today then I wanted to check the size to see how much more I needed to cut off. I usually will just check threads I make with a nut or the mating part but both ends of the shaft are still oversized so that won't work. I need to measure the threads with wires. I checked a chart and a screw with 20 tpi needs .029 wires. I don't have a set of wires and I don't like to borrow stuff like that from my work so I needed to find some wire that was .029 diameter. I thought I had a bunch of piano wire of assorted sizes but couldn't find it so I searched through a few boxes of junk looking for a spring or any wire I could straighten but nothing was the right size. The best I found was .032 brass rod but it wouldn't work at that size. My plan was to try and stretch the wire until it was right. The best way would have been drawing it through a die which I have never done before and don't have one of the plates to do it. I looked for a drill to make one but I don't have anything that size, I thought I could use a slightly larger drill as long as I only used the tip but I would have nothing to check the hole size with as I drilled it. So I decided to try stretching the wire by putting one end in my vise and pulling with a pair of vise grips. I gave it a few tries but only either pulled it from the vise or broke the wire right where the vise grips held it and there was no change in diameter. I decided to try annealing the wire so I got the torch out and heated it till it glowed and let it cool. I think copper is quenched after heating to leave it soft but I have Heated it and just let it air cool in the past and it worked. I don't know what the recommended method is for brass but guess it's similar. Anyway after it cooled I tried again and it worked, I felt it stretch right away. I measured it and it had reduced the diameter to .03-.0305 so I gave it another pull and it went to .029-.0295 so I stopped the stretching. I cut off a few inches from each end as there was more taper there and wound up with a piece from the center about 7 inches long. I cut it into three wires which should be good enough for what I'm making. Then I had to quit for the day but at least I should be ready to go next time.
