- Apr 23, 2013
- 1,078
I made a tool.to cut tapers ten years ago. And I used dovetailed pieces like that. I used dowels to lock them in place. My Logan has a production cross slide on it and the tool I made is like compound slide kind of like a sine bar. It has about 5 or 6 inches of travel and I used a piece of allthread for a leadscrew. With the tool I have cut tapered tooling for my Logan and Rockwell lathes. I made the tool so that after I have cut the taper I want , I drill and ream a hole thru both the bottom and top plate
Then mark the hole so that if I need that taper again I just pin the marked hole and I can recut that taper again. So I have marked the Logan taper and the Rockwell taper and the Morse tapers. If you want to see tool google Jimsehrs taper slide tool.
Jimsehr
Jimsehr
