Start with a 1" ID tube with 1/8" wall thickness. Run a 1" drill through it to make sure the shaft will go through. Then put a bull nose center in the tail stock and put it in the 3j and turn down the outside diameter to 1.125. No need for it to be super tight tolerance as it isn't a critical tolerance application.
Use HSS cutter and take light passes. It will hold up because the thickness in the 3j never changes and then part it off.
