Making a blow mold this week
that is really nice
can you share some information about your equipment you are using and softwares involved in the process.
steve
that is really nice
steve
Yes, I roughed the cavity on. A doosan 3016 high speed, with ballmill 0.5" SGS of 6" lenght running at 6000 @ 120 inches per minute. Cutting at full depht, that is almost 2" but only 0.025" of radial depht.
then the finish is done in a deckel maho DMU100T with a 3/16 ball mill running at 6500rpm @ 100 I/Min. Barely cutting 0.015" of thickness of material , stepover is 0.012" on 5axes continuos. I dont use coolant but use cold air to avoid thermal shock on the carbide. Eventually I spray oil mist.
Programming for the roughing can be done on any software fine. 5axes code needs a special postprocessing and we use a special german software that came with the machine.
the reason I rough in the doosan is because it has scraped square box type guides, very robust. And I take a lot of care for the DMU, by using only for finishing with trochoidal moves I minimize the jerks and extend the life and accuracy.
Finished a blow mold this week
With the course, I had forgotten to paste the finished cavities.
:goodjob:
