4
4GSR
Forum Guest
Register Today
Most spotting drills have a 135 deg. split point, which is supposed to allow you to drill shallow holes without using a center drill. I don't trust them! Where hole positions are not that critical, spotting drills are acceptable.
Also, when using center drills, they needs to be running as true as you can get it to run.
Drill chuck run out is one of the major causes of holes not being in true position. That's why you need to keep your drill chucks in good shape. The jaw don't last for ever. They need to be changed out when they start showing signs of wear. All of my drill chucks have fairly good jaws in them.
Also your reamer needs to be running dead true too. Any reamer run out will cause a hole to ream oversized and can put it out of true position, too, even though in theory generally follows the drilled hole.
Ken
Ken
