My point is: don't be afraid to have some difficult production, you need to have a start, even an imperfect work, even failure should not be a reason to stop the production!
What I haven't had a chance to say is: After heat treatment and grinding machine processing, the final result of these two tool holders is ------ miserably broken and then given up, because of my ignorance of heat treatment and material science, they reached about 58HRC, but the toughness is very poor, so it is easy to break during use, because I chose DC53 material.
I will explain my current production method and process later, I hope you can have patience and wait!
In addition, I would like to know the model and size of your tool holder, as well as the detailed data of the tool holder. If it happens to be the same size data as the tool I made, I am willing to give away an imperfect production work, because the negligence in the production process has led to some minor defects, but the accuracy and effect of the use are not affected at all. You just have to pay the cost of shipping yourself (estimated to be around $40.00)! The V slot spacing of this defective item is 100.00mm, and I used a tool holder with 99.70mm spacing. I will draw detailed size data for your reference! If you are interested in making your own, I will provide you with some drawings and production process.
View attachment 489044View attachment 489045View attachment 489046
It is not finished yet, I have to wait for the rest of the tool holder to finish drilling and threading together
