- Dec 18, 2013
- 2,377
I have the EL400 on my lathe. My money is on a bad cable, the one component that flexes back and forth. The scale is pretty much bullet proof, its just a piece of extruded aluminum with a self adhesive magnetic strip down the center, it looks like your average fridge magnet material. There is a thin stainless steel cover that slides into the extruded aluminum from the end to seal out chips, its a tight fit I don't see a chip getting in there even with help from an air hose. A chip between the head and scale, its possible you could blast a chip in there with an air hose but he said he cleaned both and re-aligned to specs. A few pics of the install would be helpful.
