- Sep 28, 2013
- 4,395
I use the LMS chart all the time. I like having the 2 columns, as others have mentioned, as it gives you different options. I've tapped holes where I've had to go below 50% thread engagement to be able to tap it without risk of breaking the tap, I've tapped others (especially thin material) at 80%. Then there are thread/ roll form taps. Sometimes I split the difference between the two columns, depending on material and thickness. Thread engagement doesn't need to be a fixed value, use what is appropriate for the material, thickness and application.
