It sits in my reject pileThat looks really good Jeff. Does the gear go to anything?
Those are very kind words. I appreciate it very much.Nice work Jeff.
Interesting that individuals have some things that are easy for them and just do them, but others would hesitate. For me, having flubbed up an arbor, I'd hesitate making this. Guess we all come from different backgrounds. I'm just barely developing machining talents, whereas it seems you can just do things like this as a quick project.
Keep at it, you are an inspiration.
The gear slipped in the mandrel. I trued to keep the forces light by being patient.For me it would be on a trophy shelf!
Even if not perfect over 99% of people would not be able to tell.
Just say it was not up to "your personal standards".
What moved?
Were you locking the RT between passes?
Would a tailstock have helped?
Thanks,
Brian
I have a couple of those. Haven’t used them yet. Good to hear they worked for you.I had good luck with the type of expanding mandrel that is two tapered wedges pressed together so they expand evenly and without a taper. The kind that expand with a screw in the end, I have little confidence in.
Is this the style you have no confidence in?I had good luck with the type of expanding mandrel that is two tapered wedges pressed together so they expand evenly and without a taper. The kind that expand with a screw in the end, I have little confidence in.
