- Jun 7, 2013
- 10,483
I, also prefer lead hammers, but soft lead is too soft and will not hold up to use very well, I was told many years ago that wheel weight (antimonial) lead is the ideal temper for lead hammers, as pure mushes over too much, and that wheel weights are the best, because it resists deformation, but is not so hard that it spalls off. I have molds for two sizes of hammers, a small one that uses 1/2" conduit and a larger one that uses 1/2 black pipe for handles, When the hammer faces are damaged so as to not be safe to use, they may be remelted and recast, but the antimony oxidizes and the lead loses hardness with each melting, this can be made up by buying a high antimony alloy bar and adding enough to get the hardness back up to an acceptable level, I also use the alloy, which is 30% antimony, 70% lead to harden wheel weight metal for casting lead bullets to Lyman 2 alloy hardness,
